dyoung14
Is getting worn out
1g can be upgraded to 200amp
3g can go to 240
3g can go to 240
What would I have to change in my system to hold that amperage? And is there increased resistance on shaft spin?
3g can go to 240
Al I need is just the Alt no need for voltage regualtion....that does not work for using as a welder...I may...may find a way to be able to connect a regulator to it, run it, and then when needed for welding, switch out the reg and bypass the charge wire for weld leads...just thinking out loud here...
Do you offer upgraded VR for the 1G as well? Or just use the stock tin can
