Allison to Fuller 6 speed swap
spg
Big Red
Columbus, OH
Took the old tires and wheels off for the last time. To get ready for the new Alcoa aluminum wheels and 22.5 tires.
spg
Big Red
Columbus, OH
Here are the new tires. 255/70R22.5 Rib tires for all 6 wheels. About 3" taller and 1.5" wider than the 8R19.5 tires
spg
Big Red
Columbus, OH
Here are the Alcoa Aluminum wheels. Polished front, Polished outer Rear and Inside rear.
spg
Big Red
Columbus, OH
Front tires are mounted on the wheels and ready to install.
spg
Big Red
Columbus, OH
Tires mounted on the inner rear rims.
spg
Big Red
Columbus, OH
Polished outer rear wheels with tires mounted on them. Tires were pretty easy to mount to the wheels with 2 tire irons. I thought they would be harder to mount but they went on to the wheels with very little prying. Used a bead seating air tank to start the process and then filled them with 120 # of air to seat the beads. Now I need to mount them on the truck and tighten up the lug nuts.
spg
Big Red
Columbus, OH
Took the first trip with the 22.5 tires last weekend. Handled well and rode nice. I am going to have to change the rear gear from the 3.38 back to the 4.10. The engine rpm is to low now with the taller tires and the manual transmission. When it is pulling the loaded trailer it does not have enough rpm to keep from pulling the motor down on anything more than just a slight grade.
spg
Big Red
Columbus, OH
The gear ratio swap has begun. To change the 3.38 ratio to the 4.10 ratio. I jacked up the truck, drained the gear lube and started to remove the driveshaft, axles and carrier.
spg
Big Red
Columbus, OH
Finished the gear install. Added fresh Amsoil Gear Lube and got the truck back on the ground. Took it for a tow with the trailer over the weekend with good results to report. The Rpm is back to the power range it needs to be in when pulling in Hi Gear. Now it will hold speed when pulling a grade on the freeway. Next step is to reprogram the computer to correct the Speedometer.
720Diesel
