Air-water CAC/intercooler on an IDI?
Is there really not enough room for the usual air/air CAC?
Plenty of people putting CAC's in obs powerstrokes. They 94 still ran the idi style wide radiator. 95 went to a different setup, but identical size radiator.
u2slow
bilge rat
Coastal BC
I was thinking those are both 'square' rads....
The wide rectangle one being 37" wide, 16" between tanks (#CU1166) and tough to get intercooler piping around.
Fision
Alaska
But easy to get small coolant hose around:Thumbs Up
71 Highboy
Towcat put my original install in the IDI Tech Articles way back in the day.
https://www.oilburners.net/threads/idi-in-the-fast-lane-or-water-air-intercooler-report.51320/
Separate cooling systems means the IC doesn't have to try and shed engine heat- which makes it more efficient. I also chose to run a different color antifreeze in mine so I can tell right away which system is leaking if it happens.
The pump has been very reliable. I just have it on a relay wired to igntion 'ON' so it is always running whenever the truck is.
My next experiment is to add a small aluminum tank on the frame rail to "store" some of that cooled water to see how much the extra capacity helps.
I did that to add coolant capacity to slow the gradual increase on a hard pull under load. Usually reach the top of the grade before max temp is reached now. Air to air intercooler drops temps from 160 to 80 on a hard pull.
ocnorb
IDIT
Wasatch Front
That’s a sweet looking old highboy!!
My first truck was a ‘69 bump side. 2wd with a cammed 390 and a sloppy 4-speed. Good times and lots of broken front shock mounts!
71 Highboy
Thanx! I bought it in 1974 with 140000 on the odo. 360 was stock gasser, but soon replaced with 390GT spec'd engine. Then along came a 460 and trans... and in 93 it got the current 6.9 with a turbo system without the intercooler. I designed it to fit with very little mods to the front end. Over 500,000 on the chassis. If it breaks or wears out, I fix it..
Fision
Alaska
As cool as EVERYTHING you said is, what surprised me is 140,000mi on a 3 year old truck IN 1974!?! NO ONE drove a non-commercial vehicle that much then. What were they doing?!
And YES, that’s a sweet truck! Nice work in maintaining it!
71 Highboy
It surprised me as well when I went to look at it. The guy was a logger from Stayton Ore. Into the Cascade mountains everyday, and back home. It was in good shape and the price was good for a kid out of hi school. The 360 was gutless to begin with. Imagine it with hi mileage!!
Laine D
Northern California
I’m curious. On a 360 (or any FE), what is considered high mileage? Are those older engines any different than the gas trucks from the idi era as far as longevity? I don’t mean to sound dumb. I know they’re great engines, we had a 410 in a boat not too long ago.
71 Highboy
Back then it was leaded gas and flat tappet cams. If you were good about oil changes, 100,000 was good life before a rebuild. Metals and machine work have advanced tremendously since then. 360 was a good engine, but 390 was a better choice. And of course, there is no replacement for displacement. Just look at the availability of large crate motors in todays world...
If you built an older engine today with roller cams and lifters, coated pistons, total seal rings, and improved guide materials and seals, I would expect 200,000 like any new car properly maintained is capable of.
1mouse3
il
Yea those truck fe are gutless do to being low compression and wear down the cylinder wall some will make it that much worse, I had one years back. They are adictive tho and have a 10:1 low mile "396" now that is night and day different in power. They make beautiful music when in the load pedal with header and h pipe.
Laine D
Northern California
Everyone loves the short beds but there’s something about a lowered long bed that looks so sick
brb5
