bennettj007
I know that he air intrusion problem has been absolutely beat to death, but I am at a loss on this one. The truck is a 1992 f250 7.3 idi non turbo, auto. Started the truck after sitting for several months and the good news was it fired right up. The bad was the after driving for around 10 miles the fuel filter/pressure light comes on. I get the truck home and start to troubleshoot. I figure a fuel pump or filter so I replace both. The pump is electric and the old filter looked fine. The problem continued and I noticed that the filter was filling with air when running. The funny thing is that the truck can sit for however long and will start and run fine. I haven't noticed any air intrusion problems while sitting but only when running. I started eliminating possible air leaks, new fuel hose from pump by tank all the way to old metal line that ran from filter to mech pump. I eliminated the tank switch and everything, just straight hose to check. Still air in filter. Drop tank and find split in rubber pick up, pull that and put a piece of hose on there to see if that was my air source during suction. Still air in filter. No debris in tank and everything looked good on that end.
I am thinking of switching it back to a mech pump but doubt that could help at all. I have ordered a return line kit to install but without the common start and stall problem I just don't know if that is the air issue. I am thinking about replacing orings and seals on the filter/separator but I am just at a loss. It just seems strange that is will start and run fine no matter how long it sits but then starts getting air and starved for fuel only when driving. The pump has been replaced and seems to be moving plenty of fuel and I think the starving just comes when too much air builds up in the filter and the injection pump starts sucking air. I can bleed the sharade valve when it does this and the truck will again start right back up until it starts to suck more air and fill the filter with air instead of fuel.
So what do you think? Return line leak? Check ball or seals on the filter housing? Or just dump some gas on it and set it ablaze? I am interested to hear opinions. I have used oil burners for info on past problems when I first bought the truck 5 years ago such as replacing the return lines and glowplugs etc.
