Air Dryers
Duke
PA
Air Dyers
What brand are you all using? Bendix? Haldex? I want to get one on my rig, but there's a lot to chose from. Any on-line suppliers selling 'em for good prices?
dondiesel444
hey Duke, I had a Bendix on my Int'l. it was mounted in a real bad spot, outside the frame rail on the passenger side right behind the exhaust stack. in the winter the blow off valve would stick/freeze and it would leak
Duke
PA
OK, that's good to know. I'm looking at Bedix's at around $300. Haldex makes cheaper ones. Do all of them have a monitor/indicator that's wired to the dash?
PackRat
Buzzard Pilot
Kansas
We run all Bendix AD-SP's on our company rigs. Except for a few of the new ones that have some other gadget onboard.
Spin on filter, easy to replace spitter valve, and heater element.
Convenience is everything, when it comes to fleet maintenance.
$300!! must be for an AD-9. I was thinking that the AD-SP's were around $250-$275.
I can check at the shop tomorrow. Today is my day off.:D
Duke
PA
Thanks, partner. I'm getting quotes of ~$300.
PackRat
Buzzard Pilot
Kansas
Just FYI, I 've never had an AD-9 die on the job. They are just a pain in the butt, if you have to kit one.
The AD-SP's are a lil less reliable, but much easier to work on.
Pacific
Gravel Rat
A quiet community West Coast of B.C.
Late reply again :D
Before you buy a air dryer make sure your compressor isn't slobbering if it is fix the compressor and throughly clean the air tanks. You don't want to load up a new dryer with white snot.
Air dryers work well especially if you live in humid areas but it doesn't replace draining the air tanks every night.
As for brand Bendix is the most common here usually they are mounted behind the passenger side fuel tank.
Duke
PA
Welcome to the M/D forums, Pacific!!! :yell:
Come back and see us often. We need more guys experienced with M/D's!
I gotta pick one up next week. Got any brand recomendations?
PackRat
Buzzard Pilot
Kansas
I'll stand by Bendix/Haldex/Midland, over anyone else, based on personal experience.
P.S. Ooops, forgot to check those prices at work. Maybe I can remember tomorrow. LOL
Duke
PA
Got an Airdryer mostly installed today. I bought a Meritor/Wabco on sale at the local truck parts warehouse for $250.
Install went pretty smooth so far. I had to fab a steel mounting bracket and used 2 already exising frame bolt holes to mount the bracket & airdryer.
I ran the heat wiring to my auxillary fuse block.
I still have to get the lines made up this week.
So far so good. Thanks for all the advice guys.:thanks:
Alleycat
