direwulf23
So, my 95 F250 5spd 4wd PSD is showing a little age, but that's to be expected at 20 yrs on and 278k+ miles. It needs new shocks, up pipes replaced, U Joint front driver side, and a new driver seat. That's all pretty straight forward. I am looking advice on two specific items.
Alternator:
I believe the Alternator is going bad. At idle/ lower RPMs (below 2000) my battery gauge is showing low charge and light is on. Batteries were bought brand new back in February. I haven't run through a full diagnosis of the issue but I expect the alternator will need to be replaced. Naturally I don't want to go through alternator Hell with failed alternators so what part/ brand would you guys advise? I've come across the upgrade alternator (3G?) but I'm not sure I'd require that added expense as I'm not currently running any accessories other than a trailer brake controller, but in the future I do plan to add more lights.
Water Pump:
I've noticed coolant on the engine cross member on the front and I suspect my water pump is leaking and I think I should probably replace it as well. What would part/ brand you guys recommend on the water pump? I'm also familiar with the "upgrade" to the International T444E water pump and I wonder if that is worth it? I very much like that the International pump has a built in coolant filter which is something I definitely want to add to my truck as well.
Those are my questions for now. Thanks guys.
Alternator:
Water Pump:
