Friend's 7.3 IDI van has the factory fuel pick up/sending unit.
This part has a beige plastic container that accepts hot fuel returned from the IP under pressure. It appears the sole purpose of the container is to prevent air from mixing into the fuel when it it returned. It also connects the shower head to the steel pick up tube. The plastic is breaking apart.
He'd like the container replaced with welded steel fuel pick up/return lines, keeping the shower head in use.
Will allowing the return fuel to shoot directly into the tank cause aeration? If so, will that cause any operational problems?
I can fab any manner of stainless steel tube designs
Thanks for your help.
