needlenose
So I found out that I have a very slow leak in my discharge hose. It holds vacuum fine, but not pressure. So I started the journey to find another one, but this is proving very difficult. All the hoses I can get at either AutoZone or Oreilly are about 14" too short. It's the same part number as the PSD, so I'm assuming it's the PSD hose. My "factory" hose has the pressure switch in the manifold sticking straight up at 90deg from the manifold. The PSD is folded over parallel with the manifold. This is all that is available for the K VIN. I even tried the '93, but that one is R12.
Has anyone purchased the suction/discharge assembly for a '94 with factory air that was the correct length? Where?
At this point, I'm getting the PSD assembly and taking it to a hose shop to have a longer hose crimped on..... ridiculous.
