Ok, thx for the input. I guess I can get my money back for the hbooster I installed because it's only a couple months old.
My biggest ? is, the hboost unit will bolt on exactly where my booster mounts?
Also, the plumbing, return line shouldn't be an issue, but what about the pressure line?
Thx for all the info.
There are several threads here on it...
First is your truck auto or manual?
Requirements for swap...
First easiest to aquire complete assembly from a pick yard complete.
Special to hydroboost brake pedal
Hydroboost unit
Mastercyl (optional but recome ded)
Power steering reerviour
Hyd lines from Pump to booster from booster to steering box a d optional factory return line....just normal rubber return line can be used.
RECOMENDED filter inline with return.
So we need to know what you have auto or manual first.
Pin location for brake pedal is 3/4" different on hydro pedal
SEARCH is your friend
