92 f350 build thread
theSHERPA
Austin, TX
Can you still buy the F Superduty springs at FORD, or are they a junkyard part? Are they bolt in? What are the benefits? Built in lift--how much over stock? Ride quality? Can they be used with the shackle reverse set up?
NO_SPRK
User & Abuser
Santa Rosa, Ca
i have no idea if you can buy them new.. im sure you can but how many organs do you want to sell?
i think they are a bolt in but they will ride like **** unless you have a cab over camper on it with a king size bed hanging over the front :-D
if your going to do a RSK then do it right and get 99+ SD springs
Nrliftedranger
North Royalton Ohio
i have an extra set i think if your interested yes they will ride stiff
got the front floor pans and fire wall fatmated and dash and floor mat installed
War Wagon
Terry, MT
It looks to be a cab and chassis. Is that correct? If so, how does the bed bolt up?
Nrliftedranger
North Royalton Ohio
i made custom mounts there will be a little larger gap between cab and bet but it wont bother me right now the mounts arent on bed is on wood blocks on top of frame
Nick
War Wagon
Terry, MT
Sounds like you've got it figured out. I was wondering how that was going to work on a C&C. Now I know it's been done and can be done for future reference.
Nrliftedranger
North Royalton Ohio
mocked up the bed a little better on the frame yesterday,,, i think ill end up moving the rear axle forward 2-3 inches so the gap wont be that bad.... .didnt think it would be that noticeable but it is
Nick
Nrliftedranger
North Royalton Ohio
well i ended up tearing the motor all the way down... quick hone job, new rings and rod main bearings. r&d camshaft, rebuilt oil cooler and new oil pan head studs refurbished heads
Got the engine bay assembled so its ready for the motor
probably not suitable for this forum but i also pulled the motor out of my dodge ram ... has a little knock.....................
ZWilson07
Cowboy
West Point, Kentucky
What happened with the dodge? We have basically the same setup just in an 06 3500 and it has been pretty much perfect in all honesty. But it is as stock as can be.
Moretorque
Dunce
Florida
I used to build motorcycles all the time, a truck is a whole nother level and I never graduated that far.
MadScientist
