92 cummins
92oilburnerr
helena, mt
i have a 92 dodge 12 valve cummins and i want to make it smoke more than it does. i have turned up the fuel pump and the rpms. what else is there to do?!!?
rebel_horseman
Rt. Wing Extremist
West Florida Republic
take yer shirt off and wrap it around the air filter...........will smoke like a dirty pig
Kev, could you explain or maybe post a picture that will illustrate this? I'm just curious how badly a dirty pig smokes. ;p
In response to the original question, if you want a lot of 'moke get a set of PODs. I've read that they are the dirtiest injector out there. The fuel pin is also a good idea. An easy and cheap fix is to tweak the smoke screw. This will allow more fuel to be dumped at a lower boost level, thereby increasing the coal fumes.
Tyler9828
