Its been a long day.
Got out to the shop around 7:30 this morning and started cleaning up the mess and making room. Was finally able to get the truck heaved back in around 10. Progress was a bit slow but figured its best to just take the time this go around and fix the little issues as we go.
Trans out... rear seal retainer pulled back off and crank repair sleeve installed. Reinstalled rear retainer and installed new clutch/flywheel...
Heaved the trans/transfer back up into place with new clutch fork. Slave and master cylinders looked to have been replaced at some point so left them be. Got the trans cross member back in place and buttoned everything up.
Decided to call it an evening after flushing the oil pan out a bit with fresh oil. It's going to take some time to get it ready to fire (maybe tomorrow if the weather holds out).
Swapped the 285s on the front... (Need to fabricate a cover for the pump gear as mine is missing)
Anyways, plans for tomorrow are to get it to the point where I can at least crank it over and build oil pressure/check for leaks. If time allows, I'll get further but we'll see.
On another note, the clutch feels a lot smoother/lighter then the stock clutch did (old clutch felt like my foot was going to go through the firewall if I pushed any harder on it). Much easier to push the pedal down. How much free play should the pedal have? Mine has ~ 1/2-3/4" before tension is felt.
Also, if the engine runs good and doesnt show any major issues, I'm going to go on and have the front and rear driveshafts rebuilt as there is a bit of slop in the rear u-joints and the front CV is SHOT. There is a local shop that will change u-joints with spicer replacements for cheaper then I can buy just the joints... little family shop that I love to send business to when I can.
I'm really hoping and praying this engine is good... with 130k on it, it should be in great shape but you just never know.
Anyways, more to come soon hopefully.
