More progress...
Finished up building a new GP harness and got it installed...
So the truck this engine came from was sold, it wouldn't start and the guy was trying to chase it down. I think I found the issue tonight....
When I hit the key, the WTS light came on and stayed on for 10 seconds or so, then went out... however, the relay never made a sound. I would assume the controller itself is getting power and working as it should, but the relay is dead.
Anyways, I started the truck and let it run for a bit (which it started after 3 - 5 second cranks). I had the cold adv. hooked up for the first time and the truck sounded very harsh and it didn't want to idle. I pulled the cold adv. wire and it smoothed out but still sounded like someone was shaking a jar of marbles.. VERY harsh rattle.
I hadn't tested the snap-on timing light adapter that I scored off ebay a month ago. It looked pretty rough but for $40, I wasn't going to pass it up. Hooked it up tonight for the first time and grabbed the timing light. Slowly started bumping the advance on the light... 0 mark lined up with right at 15 on the light and no cold advance @ 1500rpm. Gonna need to back that down a bit.
I'm curious why its so high... perhaps the previous owner was grasping at straws for the starting issue..
Any guess on how much the pump will need to be moved to drop 7*?
Anyways, shopping list is growing... Hope to order a new gp relay and the radiator come friday.. hopefully funds allow.
