I am not one to normaly post but I am stumped! The truck will not go into reverse unless it is in 4-lo. I just put a new clutch and remaned trans in today and everything else looked good and sounded good. I noticed the transfer case had a piece of metal in the bottom while draining the fluid. (I could see the piece of metal thru the drain whole.) I put it together knowing it probably wouldn't work. I was correct it would not go into reverse until I put it in 4-lo.
I also had the problem with reverse before I got a new trans. The trans had bad syncros and a bad gear so that was the reason for getting one.
Am I correct that it is possible for the transfer case to cause the truck to not to go into reverse until it is put in 4-Lo?? How? Everything else is fine.
Thanks Jason
Thanks Jason
