So while everything was apart, I took the opportunity to mess around with "lengthening" the fan clutch spring in an effort to make it lock up at a lower temp. I got a good deal on a brand new fan clutch and was just going to put the new one in, but there really didn't seem to be anything wrong with the old one either. I thought if i broke the spring, I still had a new clutch available so I gave it a try. If I understand correctly, the "tab" on the spring that is held in the "pocket" with the rtv needs to be "shortened". Shortening up the spring tab "lengthens" the rest of the spring and deceases the spring tension. This allows the spring to act on the clutch shaft sooner and lock the fan up at lower temperature. Okay, so here is what I did:
I pried the spring tab out of the pocket.
That rtv also needs to be thoroughly cleaned out of there.
You can see the spring tab is free from the pocket now.
I also cleaned the old rtv out of the pocket.
I measured the spring tab before I started bending.
I carefully shortened up the tab by relocating the bend with a pliers.
IIRC, I shorted the tab about 3/16" .
I put the tab back in the pocket and secured it with fresh rtv.
I used Ultrablack because that is what I had on hand.
I have no idea if this fan clutch spring mod was successful or not as the weather has been too cool right now and I haven't really worked the truck either. Thanks for looking.
