tbrumm
Thanks, Al. I don't think the heads need a valve grind as there is only 108k on the clock now. I wanted to replace the valve seals and springs while I had the heads off, although they may not really need replacing. However, the truck used to sit a lot when the Air Force had it, so the valve seals may have hardened up over time. In any event, it certainly won't hurt to replacethe seals for longevity, and I already have them. I purchased a NOS OEM Ford valve grind gasket kit which has the valve seals, but no "sleeve" to install them over the ends of the valves. I wonder if a short piece of thin plastic tubing slid over the valve end would work? If I understand correctly, the only thing that tube is doing is keeping the seal from getting nicked up on the groove for the keeper.
