6.9L Liquid to Air Intercooler Install
Oil_In_The_Gas
Sacramento, CA
I'm new to this forum but after thinking about doing this upgrade for the last couple of years I wanted to share the results. I often tow a 21ft Toy hauler that weighs somewhere around 6500 lbs loaded. Going over the Sierra mountains and the long grades I felt like the engine would heat soak and have power loss towards the tops of the grades and some extra power to hold 4th gear would be really nice.
The truck has a ATS setup and is pretty much stock besides that and the exhaust. I did a ZF5 swap a couple of years back as well. I could get to 1150+ degrees on the EGT if I wanted to, so I was hoping for a decrease in exhaust temps too.
I ordered the 600hp universal kit from Frozen Boost, ripped out the old ATS intake and also removed the radiator overflow and winsdhield washer tank to make some room. I found that the intake manifold inlet is the same as a standard 4bbl carburetor top so I made an aluminum adapter to be able to accept a 3.5" silicone hose to plumb in the intercooled air.
I have the cad drawings and .DXF drawings for anybody that wants them.
Next I removed the grill and installed the radiator.
I found I had to tilt the intercooler a bit to get it to fit, I made some steel brackets to support it, bought a bunch of 90 degree silicone bends and a couple of adapters to fit the turbo. Cut the 3"dia .060"wall aluminum tubing to length and bead rolled the ends. Assembled and disassembled many times and got things to fit half way descent.
I also added a couple of cheap temp sensors to check to see if the system actually works. Overall I'm pleased with the results. I see about 30 degree drop on intake temps at freeway speeds and when pulling the hills about 50 degree drops. On sudden acceleration like getting on the freeway and such 80 degree plus drops are seen. Egt's wont pass 850 now. and boost seems to be down only 1-2psi but it could be because I'm now taking a reading at the manifold instead of the turbo.
Oil_In_The_Gas
Sacramento, CA
About 450ish. 300 for the kit, but I ended up not using the electric fan that comes with the kit and another 150 or so in tubing, hose, elbows and nice t-bolt clamps. Here's a pic of temp display when driving on the freeway with the trailer, a/c on, and 110 outside. And that's brake vac not boost.
Mike_42
Kid Mechanic
Canton, MS
Very nice, thanks for the right up. Ill be doing an intercooler soon after I get my BW turbo.
thanks for posting this. I was thinking of going water IC due to the lack of airflow on the winch bumper of the Sulaco.
HS108
Diesel Newb
Connecticut
Looks cool!!
Maybe a dumb question, but how much would an air to air intercooler lower intake temps ?
Is there that big of an advantage to air to water
nice. heres how I did Asmiths's
HS108. The air to air is the most commonly used intercooler so even though I don't have any numbers for you, it does work well. I think that the biggest advantages of the air to liquid would be that when it's hot, the liquid would absorb more heat from your boosted air, quicker. I don't believe that the hot air cools as well as the liquid does.
Thatoneguy
Boerne, Texas
Hey I have the same boost gauge! But mine is on the turbo. Very nice write up and clean work too. Wish I had some CNC equipment... Someday when I grow up... Lol like that'll happen.
Oil_In_The_Gas
Sacramento, CA
Looks cool!!
The air/air works well, but on these old slant nose trucks there is no room for the big air intercoolers unless you want to ditch the a/c condenser.
03wr250f
Hamilton/Montana
I would love the files on how you made that intake hat. That is so darn sweet! I love it!!!!!! It looks awesome man!
lewisstevey7
