6.9 Superduty
grog85
novi,mi
What did you end up doing for motor moumts? And did you move or modify the crossmember?
Mikey89014
Henderson NV
Just built these ..they are made out of one and a half inch angle iron into quarter inch thick steel plates.. the crossmember I did not have to modify.. I might have to shorten the driveshaft maybe we will see.. has a little bit of movement but maybe not enough..
I made custom radiator mounts as well for an aluminum IDI 2 row Champion.. Will post those soon too.
Mikey89014
Henderson NV
Heres a pic of motor mounts installed and underneath .
Mikey89014
Henderson NV
Radiator , shroud and IDI fan installed
pastorjeep
Gatesville NC
Looking great! Can you explain how much od the factory IDI mounts you used with your fabricated mounts and how you tied them into existing? frame holes.
Mikey89014
Henderson NV
I used the factory mounts , then fabricated those other mounts that add to them. They basically raise the engine 1.5 inches and forward from the original frame holes by 2 inches . Requiring no mods to frame or original motor mounts . They are basically sandwiched between frame and original mounts..
