Yes! sounds like a win. That looks so clean in there you are about to convince me to stick this low miles Jasper 7.3 I have in a SD body. If I understand correctly you have shifted the whole drivetrain forward two inches?
The transmission and transfer case are roughly 1.5 more to rear and engine mounts 2 forward from original . Engine itself just matched to tranny position then adapted mounts to frame . This way no mods to driveshafts or frame as of now either. The adapter mounts are just sandwiched between frame and original mounts. The radiator mounts are fabricated from rebar and steel plate with rubber mounts on the bottom.
I just did , thanks. I was hesitant because it is left hand thread , but I just tapped it for a larger RH bolt and thread locked it. It is hard to find a Lh helicoil ..
I just found out the E4OD case (which i'm using) has 2 missing bolt bosses for the shift linkage bracket, as opposed to the 4r100 case that the truck came with originally. I'll have to fabricate a linkage cable and bracket so I can test my first ever rebuild on an automatic transmission. So far all I can see is the the transmission is pumping fluid through the cooler lines (good sign) and there are no leaks anywhere yet...
