6.0 trans cooler&external transfilter install
tknomaj
Anaheim Ca.
f450 e4od's and 4r100's have 3/8ths cooler lines and not 5/16ths In the upgrade idea i got external trans filter kit for 4r100 and fittings from f450
e4od I did not like the filter mounted to outside of frame would have hung to low and exposed so here is were i mounted it and made new lines to go forward to core support for hook up to 2006 6.0 transmission cooler which has 1/2 " connectors. I used the braided stainless lines to go forward from transmission to filter and hard line from filter to cooler and hard line back to braided stainless line will finish next weekend have to remove grill to mount cooler but here is what i have done so far:D Broke one of my favorite benders bending these lines :eek: it served me well for 20 years
tknomaj
Anaheim Ca.
6.0 trascooler
more pictures
tractorman86
Buckeye, AZ
looks great! now then running an external trans filter do you filter before or after the cooler, or does it matter?
tknomaj
Anaheim Ca.
6.0 transcooler
I asked people this same question and everyone said before cooler and in output line and not return checked the new PSD's with factory in line filter and they are set up the same way:D Oh forgot my manners thank you
Cv axle
