4X4 Transfer case
Geno
Noble Ok
To all that has a 4x4
Anyone having trouble? 03 d/a dually 4X4 that has had 4X4 prob lems from day one. 70 mph low range light comes on, instant hart attack. After numerous trips to the dealer this is finally repaired but the 4 wheel drive won't work. After numerous visits to dealer and ******* to factory rep, they extended our warranty, 65,600 miles, got stuck in sand, 4X4 not working, called wrecker, sent to dealer, dealer says transfer case bad, wait 1 1/2 weeks for rep to say ok to replace. This is the surprise...This has been an ongoing problem with numerous 4X4's gas amd diesel. The oil pump wears a hole in the case and all lube is lost. There is a fix on the way that will be here in March of 04 and this problem shows around 50 to 60K miles, surprise, you get to pay if you don't have extended warranty. they want to put old part# transfer case back in ours and the fight is on again. We are assuming the factory wants to sell the new fix to the ones out of warranty. Call this lady at the factory and don't take no for an answer and possibly you may get an extension, we did. By the way, the fix will be around 3800.00. Call Debbie Palmer @1-313/667-7153 and keep calling til you get satisfaction. This is a company truck that we use every day in our business.
Geno
Found out that this a ongoing problem with all GM 4x4 mdls gas or diesel 2001 thru 2003
Geno
REM70
