4x4 K4500 & K5500
DBogo
Upstate NY
has anyone seen these its about time gm cought up to ford with the 4x4 they are pretty sweet trucks ;Sweet
ISurvivedNMU
Michigan
Yeah, hey are real cool, but they are pretty big or the light payload they have.... I wish GM would put a solid axle under there 3500 chasis and beef it up to a 4500
Duke
PA
They are nice, but kind of massive for their payload.
Looks like a 5500 4x4 19,500 GVWR with a 11' dump on it might be legal with a 4+ ton payload. I looked at one speced-out on a dealer's lot. They weighed the truck after it was built. It was 10,700lbs empty, so the payload was only 8,800lbs.
My concrete contractor has a new F-550 4x4 17,950GVWR. He has showed me weigh tickets empty of 9,500lbs. He has a legal payload of 8,450lbs.
Less than the 5500 4x4, but not much less (350lbs). Considering the size of both vehicles, you'd think the 5500 4x4 would carry a lot more weight than the puny F-550 4x4.
Something tells me the 5500 might "handle" the weight a bit better. It has 245/19.5's versus Ford's 225/19.5's and bigger sway bars.
The frames are interesting: GM utilizes a big single frame rail, while Ford was using a doubled, but smaller height frame.
The 5500 suffers from extremely low ground clearance under its' rear differential. I'd guess 7 inches.
They are really neat lookin trucks with 4WD.
REM70
