3rd and 4th gone
DBogo
Upstate NY
were diving in my buds F150 with the 300 I6 its has the 5spd either the ZF5 or the F1TA? maybe and 3rd and 4th are just gone it goes into them but it just revs like its in neutral can any of you guys give us some advice soon we need help asap thanks guys
DBogo
Upstate NY
more info its a M5R2 mazda built tranny we flushed the tranny i got tranny fluid all over myself (that was fun) there was quite a bit of metal in there the magnetic drain plug was completely covered in metal and the tranny fluid that came out was black and metallic looking so we put some more in and nope same exact thing so were thinkin we need a new tranny in this puppy screw this mazda built crap would a ZF5 or ZF6 fit behind the 300 I6
jlayne
Bondo Bandito
Milledgeville, GA
if you got a older zf5 with a 351W/302 bellhousing it will physically bolt up to a 300 I6, they carry the same bolt pattern... now as to what clutch and flywheel you would need i'm not sure
if i was attempting the swap i would probably use the throughout bearing from the V8/ZF (it will be internal and hydrolic) , you will have to use a 300 flywheel because isn't balanced like the 351 or 302.. IF it (flywheel & clutch pack) is the same thickness as the V8 flywheels then it would be a piece of cake
when i swapped my half ton from a 300 to a 351 i used the 300 bellhousing 351 flywheel and clutch and 300 throughout bearing so that it matched my tranny snout and was the right thickness
sounds like a cool swap... i think it wouln't be that hard
