3g alternator with V belt?
Greg5OH
MI
Hey guys, just wondering if i can get a 1 wire 3g alt from a 93-94 and jsut take my V belt pulley and put it on that one, and it will all bolt up just the same?
Thanks. Want to eliminate as much wiring and get some more amps where I can.
theguruat12
Certified Tinkerer
Albuquerque, New Mexico
I got my 3G from a 3.8L 90's Taurus, swapped the pulleys easily, you will need to grind some of the ribs on the front case down a bit. Easy though.
Greg5OH
MI
dhould spring for that when my alt took a **** last winter!, now i got a 1 year old 2g alt that wont be much good to me lol.
82F100SWB
Sioux Lookout, Ontario,CA
You can grind the front of the case, or put a thin washer behind the pulley, either way works. I did the washer on my 460 truck with no issues.
opusd2
BFE, WI
I've got the washer behind the pulley on mine, and it lines up nicely.
opusd2
BFE, WI
And this was the best investment I have ever seen in a vehicle. I've always used a Delco 10SI on tractors when converting from a generator or external regulator, but I think this may be the route I will take from now on. I should have done this when the alternator took a dump on my 79 Bronco earlier this year, but will probably do it when I repower that Bronco when I finally 86 that 351M for something worthwhile. It's just as easy to do as a Delco rewire, and has so far been much more dependable than a couple of tractors I've done since.
Greg5OH
MI
good to know. my 1 year old lifetime warranty oreiley 2g is starting to flicker the voltage gauge again like my old one did. fackkk offff.
so what other vehicles have this? 93 trucks, mid 90s taurus, and?
do trucks have higher amp output? i knwo theyre some 130 amp verions, is that the taurus one?
dunk
Dunce
NJ
I have a 105 amp 10SI on my boat, easy install. Seems to work great compared to the original 50 amp unit it replaced. I know they're older tech but is there a big advantage to 3g other than higher capacity up to 160-200 amps? 10SI is much cheaper.
Greg5OH
MI
thanks, I see ~150 amp unit son ebay for 120ish all day. Thats a fair price id say., comes with V belt alreayd too!
junk
Paullina, IA
I got my 3G from DB electric. Ordered it for a Taurus. I don't remember what the factory alternator is rated, but I know the taurus is a nice upgrade for the money.
I've got 3 2G alternators if anyone needs one. Ones a brand new rebuild!
The serp belt alternators mount different. Don't get one for a serp mount 92- up truck. I bought one from uhaul on ebay that was actually for a tall deck 427 motor. Its a 3G with the v belt pully on it. Looks identical mount wise to the 1 g on my engine. For what it's worth.
CDX825
filtration nut
Litchfield,Ohio
Order one for a 95 E150 4.9 with AC. It will have the right hole spacing 8.25" and the right clocking witch puts the connections towards the passenger side.
