30 gallons is what it takes to flush rad of shiddy green coolant.
larson
Springtown,texas
30 gallons is what it takes to flush coolant system of shiddy green coolant.
Just got done flushing the old hag and by what it reads on my ph strips its straight water. No need to unplug the block drains if you have the time and a place to dump the coolant mixed with water until its clear. Just thought id share the info. And that's 4-5 gallons at a time of sink water/city water nit well water with about 10-20 mins of idle time with 60seconds of 2,000rpm on the gas pedal to let the t-stat open up with the heater on. Time to fill her up with the pink juice and call it good. I decided to go with fleet charge and return the Napa cool.
Good choice.
I only removed my driver side block drain. You wouldn't believe the junk that came out.
larson
Springtown,texas
Good choice.
Yeah thanks to the guys on this forum I was told exactly where the block drains were located the problem was I couldn't find my swivel sockets any where and that put an end to that attempt or i would have backed them out and let them drain.
