So I can't catch a break. What I hoped was a quick seal change is turning into a rebuild.
Pulled the rear hub on pass side and this is what I found.
Outer bearing
There is a small ridge where the rear bearing rides. The seal lip looks good. As you can see the bearings are crispy. I haven't knocked the inner bearing out yet but I'm not changing one and not the other.
So I'm searching for a bearing kit. Axle looks okay so I think stock replacements are fine.
Now the real question is do I just go ahead and do both side out of hand. There is evidence it's been apart and it didn't leak as far as I could tell.
My shop manual says to discard the axle bolts but they look okay. Should I just clean them up and loctite them?
So I'll go ahead and say that this is the axle that had the dually adapters on it but it also was a truck where the frame had been broken and plated so I'm sure it's been abused.
Let the conspiracy theories begin.
Outer bearing
