Where can I get the correct 7.3l idi turbo piston rings? Do powerstrokes fit?
Shawn MacAnanny
Delaware
I've been told the idi turbo piston rings are the same as the 7 3l powerstrokes. Is thst correct? They have two keystone rings. If not where can I get the correct standard bore rings? I was looking at these
1994-03 Ford 7.3L Turbo Diesel Power Stroke Mahle "MOLY" Piston Rings. Your choice of over sizes!! (STD Bore) https://www.amazon.com/dp/B01F41YS34/ref=cm_sw_r_cp_apa_bA7FxbQG9JV1W
Shawn MacAnanny
Delaware
Thanks! I called diesel performance who sells new Mahle pistons for the turbo and they said the Rings are the same. I ordered a set but they won't be here for a week
Shawn MacAnanny
Delaware
I just spent some time looking up measurements and i dont think those powerstroke above will fit the turbo IDI pistons, the powerstroke measurements look the same as the non turbo but not the turbo so i found this set that looks like it should fit my 94 turbo idi based on the measurements the machinist told me they were
http://www.ebay.com/itm/252426356726
maybe the Mahle replacement turbo pistons are cut the same for power stroke rings, but i think my factory pistons are cut differently
tke395
