farmerscotty
- Joined
- Nov 11, 2006
- Posts
- 42
- Reaction score
- 0
ok my 92 has probably shelled the torque converter........very bad noise and I have only drove it like 4 or 5 miles with the noise.....So that is not bad that way. I am going to have it pulled out and a new torque converter and front seal and pump put in.........anything else I should have them double check. If the rest is trashed.......(filter and fluid changed less than 1 thousand miles back) nothing bad was in pan then. I plan on having a reman Ford tranny put in.......2200 bucks.......ouch! but 3 year 75 k warranty.
If you have been thru a deal like this.........let me know what to do.........
truck only has 125k on it..............
PS found a dana 70 rear end for the 83 for $100 dollars.......life is good there. Running a 40%mix of atf and diesel in it.......so far so good started like normal at 4 F couple of weeks ago.
Thanks for advice
scott
Thanks for advice
scott
