>>> LIGHTS ??? WHO SAID LIGHTS ??? <<<
I will probably forget a few, but here is a short list of what I can think of :
Plain old relayed headlights, of course, with manually switchable BRIGHTS and DIMS together.
Two big powerful 6" round FLOOD/FOG lamps between the uprights of the grille-guard; fog just disappears when these are lit.
Two outward angled 5" round FLOOD lamps on brackets under and behind each side of the front bumper; these are worth their weight in gold when turning into blind roads/drives.
Two big 6" round multi-million candle-power SPOT lamps atop the head-rack; these babies light up the night; I can see deer long before they decide to jump across the road.
All of these lights are wired through master-switches and can be operated automatically by the dimmer-switch, ON on demand, or OFF at all times.
Now for seeing what's aft :
Two 55-watt rectangular driving lights mounted high on the head-rack that light up the entire flat, plus the whole area behind and around the flat.
All REVERSE lights are relayed, even the many little 1156 ones in the numerous tail-lights.
Two more 55-watt rectangular driving lights reside tucked underneath the flat, angled outward at about 45*, plus one big round one in the center facing straight back; I can see the whole countryside behind me.
The CARGO lamps and REVERSE lamps are also controlled by master-switches that allow automatic operation with the gear-shift, being ON regardless of reverse-switch position, or being always OFF, regardless of shifter position.
I have a bunch more various lights just waiting on time and space.
Plans are in the works for strategically located flood-lights under the hood that will light up all possible situations that may come about out on some dark lonely highway.
A big 110-555 160-amp
Leece-Neville don't even flinch when all these lights are lit, plus anything else that may be ON at the time.
