When I looked at the 94 F350 SRW PSD that I'm getting, I forgot to write down the axle weight ratings. Does anyone know what they might be and what the GCWR might be, with the ZF 5?
ZF5 and 4.10s was 15k IIRC, would be 17k if you had the E4OD with the same gears - my truck is currently buried under snow so I can't look up my manual to make sure, so maybe someone else can confirm these numbers?
