Went to a local o'reamlys today the kid wasnt very helpfull in my search for a water seperator they didnt have the base i needed for the 6.2 or detroit filter conversion
However he was able to give me the specs of the filter that the stock 6.9 uses
I stumbled across a filter with drain that will fit my base its just twice the height but id rather relocate my stock setup than have to buy a 44 dollar base
only thing is its a different micron the stock setup is 6 micron this one is 10 i dont fully understand the micron rating but im assuming it will work with a filter base relocation of course.
Its a wix 33337 Part Number: 33337
UPC Number: 765809333376
Principal Application: IHC DT360, DTA360 Engines (10 Micron)
All Applications
Style: Spin-On Fuel/Water Separator Filter
Service: Fuel
Height: 9.404
Outer Diameter Top: 4.282
Outer Diameter Bottom: Closed
Thread Size: 7/8-14
Burst Pressure-PSI: 425
Nominal Micron Rating: 10
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
