7.3 idi cavitation
Imo, also less likely to see cavitation on a n/a engine.
I've personally seen it on a 93 with a banks turbo.
Cant remember if it was that block, or the replacement that appeared to have the cylinder walls checked. Had a plug in each wall under the valley pan. Pics are on the forum somewhere.
yARIC008
Drives really slow
Orlando, FL
Have you guys not read my cavitation article? I’ve had two N/A engines cavitate through. If you don’t use the system cooling additive it will cavitate through, just a matter of time. Our cylinder walls are so thin and the compression ratio is so high, it’ll make it cavitate as the walls flex.
yARIC008
Drives really slow
Orlando, FL
Is it safe to say if you make it to 150k without cavitation you’re probably not going to encounter it? I’m right about there with my 94.
No sir, it is not safe to say you won’t encounter it. Add SCAs though to the proper level and then you should be fine though.
YJMike92
NW Arkansas
My local machine shop said number 7 and 8 cylinders were the most prone to cavitation.
Jason1377
Arkansas
Never knock on wood any coolaint issues and have never changed radiator fluid since I have owned my 1993 f250 n/a for past 5 yrs it currently has 171,580 original miles original motor everything but usual replacement brakes tires n minor matience. Have never had a heater no a/c issue since I owned it.
03wr250f
Hamilton/Montana
when you say our cylinder walls are thin, have you seen how thin 6.7 cummins walls are? our cylinder walls are more than 1/4'' thick
that being said 7&8 are most prone to cavitation, It is still a rare thing to happen, generally on higher milage motors. providing coolant additives were kept up on you will be just dandy.
They also run way lower compression ratio. Between 16.2:1-19:1 depending on output.
But, cummins does still call for sca.
olsen726
