aggiediesel01
Houston, TX
This is a little bit pie in the sky but I'm curious so please don't poo-poo the idea yet.
In 2006/07 F-series are the electronic modules in the interior that run all the niceities in the high end packages VIN Locked or otherwise have to be initialized/registered to the PCM? How about the speedo cluster? If so, can they be matched to a different VIN/PCM with the full ford version of autoenginuity?
I'm working with a '06 xl crewcab basement model (not even Crusie Control but has upfitter switches and brake controller) and I'm investigating options to upgrade the interior to pretty much everything offered in 06/07.
I'm sure some will say just find a truck with the options I want and sell what I've got but that's not something I'm considering yet. My area has a bunch of salvage yards with these trucks in it and I'm willing to strip an interior completely (including wiring harnesses and window brackets) if that's all it takes. If a bunch of computer reprogramming is required, then maybe a different path might be considered but for now I'm interested in knowing what's possible and a general outline of what it might take. Anyone know if the high end trucks also added additional sound deadening or insulation?
How much of the XLT package wiring might cross the firewall that might require additional wiring? Cruise control function? Exterior Temp function? Any others?
aggiediesel01
Houston, TX
Thanks for the reply, so you think it might just be plug and play once the wiring and modules are in place?
aggiediesel01
Houston, TX
Thanks again.
I've searched this and other sites and can find a lot on swapping seats, painting door cards, and dying leather but not much on adding the factory power windows, locks, keyless and all the dash goodies unless people are swapping between platforms and those usually devolve quickly into cutting and splicing and modifying things which I think can be avoided by staying in the same platform. That's why I'm here asking for any other knowledge, experiences, references, thoughts, prayers, or whatever will help me get enough information to decide to make a plan or move on.
Double-S-Diesel
parts seller
derry pa
i have put power windows and licks in my 84, my 96 and my 03
on the 03 i used 99-2002ish switches and motors, even used some explorer pigtails.
the later models use different switches that go thru the bcm the only other option for factory wires is a complete donor
IDIBronco86
