2 Piece Driveshaft Greese
Neal_P
Anyone know the ford part # for this stuff? Or is there any aftermarket stuff that can be used. Thanks.
jlayne
Bondo Bandito
Milledgeville, GA
i use just regular old high temp grease in mine, and all the other grease points... i'm sure ford has some outrageouly overpriced grease if you wanted it
Neal_P
I had read from some others that the regular greese didn't work as well. GM also has a special greese for their driveshaft. Of course they were smart enough to put a fitting on it so you don't have to take the shaft down. cookoo
NJKen
is a daddy!
Central NJ
I use Mercruiser spline grease on mine. It is suposed to prevent spline wear. The splines on the I/O boat engines take a beating and hold up good. Maybe it's the grease! LOL!
Ken
jlayne
Bondo Bandito
Milledgeville, GA
Ken
i have used marine grease on my trucks before.. it is far better about washing off... marine grease stays where you put it! water doesn't effect it near as much
but it is a mother to get off your hands and FORGET about getting it off your clothes
