1993 ford diesel 4x4 super cab
wgargan
Durham, NC/Chico, Ca
1993 ford diesel 4x4 super cab NEW PRICE
unexpected move to west coast forces the sale. It was going to be my truck to keep "forever" thus the WVO and nice interior, but life keeps taking crazy turns, now i have to go to the west coast and need this and my trailer gone. see picts below
not all the picture uploaded. I wil put more up later, and I will put more description. But basically the truck has been well cared for. when things needed replaced they were replaced.. reverse grinds sometimes, but it did not do it today while running errands... sooo who knows i have a long list of work and MANY receipts i think i will take pictures of them. But i will gather thosoe ver the next few days and write up a good description.
I will let it go right now this second for $4000 but please come look at it and make an offer.
pics
http://landscapetoolsforsale.googlepages.com/ford1993f-250forsale
wgargan
Bought it in detroit. stored indoor for winter since '96 (per PreOwners) the rust isnt all that bad if you look at it. the one bad spot I have with my finger in it is the worse of it. I am open to offers, would like it gone sooner than later.
wgargan
new video
http://www.youtube.com/watch?v=V8YJupJzWsc
and parts replaced
Parts with ford part number and receipts
4c2z19a706ba
Hvac - Controls - Blower motor - Resistor
f81z4800db
CENTER BEARING ASSY
f3tz2c342a
BRK & CL PDL SHFT BS
e69z7526a
Clutch - Clutch & flywheel - Pedal shaft bushing Pedal shaft bushing
fotz12b533a
Electrical - Ignition system - Diesel controls - Glow plug module assy Glow plug module assy, f250 pick-up - 1992-96, 1997-98 hd 1992 - 1998
f4tz13713aa
Electrical - Chassis electrical - Switches - Door jamb switch Door jamb switch
f5tz16720a
Fender - Exterior trim - Nameplate - power stroke power stroke Back 1995 - 1996
f2tz14301d
Electrical - Chassis electrical - Battery - Negative cable Negative cable, f250 pick-up, 7.3l diesel, left - 1992-96, 1997-98 hd 1992 - 1998
f2tz14301c
Electrical - Chassis electrical - Battery - Negative cable Negative cable, f250 pick-up, 7.3l diesel, right - 1992-96, 1997-98 hd 1992 - 1994
e9tz11450b
Starter - Solenoid relay Solenoid relay
f2tz14300e
Electrical - Chassis electrical - Battery - Positive cable Positive cable, battery to relay, f250 pick-up, 7.3l diesel - 1992-96, 1997-98 hd 1992 - 1994
f3tz2c342a
d2ly13783e
LENS-INT LP/BUG-EYE
F2tz7a543d
Clutch - Hydraulic system - Master cylinder Master cylinder, f250 pick-up -
E7tz7a554a
LEVER-CL PDL
E3tz7a564a
Clutch - Hydraulic system - Slave cylinder Slave cylinder, f250 pick-up
F5tz7a512a
Clutch - Hydraulic system - Hydraulic lines Hydraulic lines, f250 pick-up
1c3z11a152aa
SWITCH ASY-CL MLTPL FUNC
Parts without ford part numbers BUT WITH receipts
2 replaced leafs and 2 added leafs
2- Upper ball joints
2- Lower ball joints
3- U-joints
8-injectors
Injector return line kit
4- NEW @ 181244 miles Dunlop Rover AT LT285/75R16
Tires have a free lifetime replacement. If local I will assist in getting them replaced if needed.
Injection pump
Missing receipt and part numbers
Injection pump (by me)
Wheel cylinders (by PO)
Calipers (by po)
Injector line clamps (by me)
Loganm223
