So I am in the middle of my engine and zf5 swap into my 1990 f350.
As I am buttoning everything up, I discover a sensor that isn't on my 7.3L idi with the zf5.
However the engine/e4od that came out of the truck, has a throttle position sensor mounted on the injection pump.
Is it safe to assume I can just leave the wire unplugged and not install the tps on the engine attached to my new zf5? I tried searching on here but didn't come up with much of anything. I also used the manual transmission harness out of the donor truck.
Thanks
Thanks
