good morning and happy veterans day.
i tried not to post another ZF5 question.
however after researching all day yesterday.
i have accomplished all of the hardware issues.
i am asking for expert advice as to which one to run with what....WHAT?!?!!?
i have 2 rigs, that i will be running a zf5 in.
1, 1963 ranchero, with a 97 7.3 DIY 4x4, D60's front and rear with 4.10 gears with an aprox weight of 4000 lbs
currently, this has a ZF5 with a pn of
1307-050-081 / F2TA-7003-SA
this one decoded as a F450 trans that i can pull the brake off of and install a transfer case
i have 2 transfer cases that i can bolt up to this.
A) 13-56-065-909
B) 13-56-039-907
is one of these transfers better than the other?
the only thing i see physically different is the type of driveline mounting, and selector hardware.
2) 1987 F350 w/ a 94 7.3 IDI with a ATS 093 4 wd also with 4.10's with a weight of 6300 lbs
this rig currently has a T-19.
the pn i have slated to install in this rig is:
1317050012 \ F7TA-7003-BA
TRANSFER # 4407-25 / F6TA-TA
i could not find the gear ratios on either of these.
so, if anyone could give me a hand, id greatly appreciate it!
ALSO, please give me your opinions on what manufacturer of clutches you guys are partial to.
i need to order some parts!
A) 13-56-065-909
B) 13-56-039-907
