ZF transmission temp. sender location/tips?
BrandonMag
Dana 50 rebuilder
Oregon east
I've been getting the F250 ready to bolt the turbo on, and I'm in the process of getting the gauges installed. I picked up a boost gauge (0-15 psi), a pyro (0-1500*), and a transmission oil temp. gauge (100-280*). The gauges are ISSPRO.
My question is about the temperature sender for the transmission temp gauge. I've got a ZF and I'm a little apprehensive about drilling into my case (although I do realize it needs to be done). My plan is to drain the tranny and carefully drill the correct size hole in the case. I've got a tap that I can use for cutting the threads. I'm hoping I'm able to catch all of the shavings. ;Really
Any tips or pointers from someone who may have done this?
alienturtle
Human
Ripon, CA
what i would do is drain the oil then take off one of the little side plates. i would drill a hole in that and weld a bung with the 1/8th NPT onto that.
1 you dont have to do any drilling near your tranny
2 if you eff up you just get a new side cover piece.
BrandonMag
Dana 50 rebuilder
Oregon east
Now that is a damn good idea! ;Sweet
BrandonMag
Dana 50 rebuilder
Oregon east
I just checked out sinister diesel and didn't find any pto covers. :confused:
tech51
San Antonio, TX
Made by Fabcraft they are 70.00 or 125.00 for two. If you run two of them you do a cooler set-up + temp gauge. As soon as they send me the info I will post it up for you all to see.
alienturtle
Human
Ripon, CA
drilling a hole and bungs are cheap... i cant remember the last time i have heard of a zf5 over heating.
gatorman21218
Ashland VA
Why not put it in the drain plug? I realize that the threads arent right but mcmaster carr or some place migh have some bushing to make it work. I dont think its worth the risk of drilling into the case.
