jibronee
Putting together a 88', 2WD work truck with 7.3 idi.
1. Will a 7.3-zf6 be a straight bolt in to my 88'-7.3? From scouring the forums, it seems like I would delete the thick, steel plate as the zf6 has a thicker bell housing flange?
2. Can I use the zf6 flywheel/clutch set up on my idi 7.3? Or will the SMF conversion be needed for an 88' 7.3?
3. Is there anyone that has done this swap? I know it can't just be a straight in swap, or can it?
Thanks,
Chris
Thanks,
Chris
