[WTB] Radiator Trans Cooler Plugs?
mntwins7
Broken 6.9
USA
I don't know exactly what they're called, but I'm looking for the two plug things that go into the radiator that the two trans oil cooler hoses plug into.
Part number would be great too.
Thanks!
Why do you want to plug them, there the best temperature control you can have for a transmission, other than a 6.0 air to liquid cooler.
There is no PN for them, if you truly want to plug them, go to a hardware store and get a couple of plugs if there female holes. There probably 3/8" NPT. Get brass.
mntwins7
Broken 6.9
USA
There is no PN for then, if you truly want to plug them, go to a hardware store and get a couple of plugs if there female holes.
No, I don't want to plug them. The piece that the hose plugs into is leaking, so I'm trying to find the replacement part.
from what i recall, its a tube fitting.
could be wrong tho,
Clb
Another old truck
nannyfornia
On the 86 in your sig? Ive gotta 88 fsm .....but finding a replacement either ford or a "GOOD" tranny shop
