ShadetreeV
Needing a set of springs for the d60 setup ony 94 f250. . .looking for the rear lift blocks as well
Located near Redding CA.
if it's IFS, you're going to be running around in circles.Thanks a bunch for the heads up!! I'll have to check it out
IFS uses a "reverse arch" spring.Do they not use the same leaf spring?
'85 and older was D50 IFSIfs=3/4 ton most the time. You need 1 tonne
