UPDATE! 1of2
Ok guys the last 2 days went well. Just want to update with some pics. I met my high school ag teacher i am really good friends with today. Our high school has a full mill and lathe. I got a sweet lesson today on how to use the mill to mill my rocker towers to accept the arp head studs. He showed me how to do the first one and i finished the other 5. It was really cool learning how to use it. I have watched him use both the lathe and mill a hundred times and finally got my shot at it. Lubed all the studs and nuts and got the head torqued down to spec. I went 20 - 40 - 60 - 80 - 90 - 100 - 110 - 125 is what arp says they want them at. By the end of that going through the sequence of 26 head studs wow my arm was worn out haha. Side cover is on and new motor mounts are on. Tappets are in as well as the cam. Valve adjustments are all done and valve covers are on. I ordered the valve cover with the oil fill in it but i was shipped a regular valve cover. When i pulled this motor apart a piece of the crankshaft thrust bearing full off and went into the pan. There was some metal in the bottom of the pan from it. The oil pump looks like it might of seen some of the metal. Im not chancing an oil pump with this build so the front cover is going to have to wait till i get a new pump. All in All good good day. Lots more to come stay tuned!.
Tappets in and held up.
Cam goes in and timed to the crank
My KDP fix. I did this when i first put the motor in. Still have a pin in the hole. Must of worked lol
Pushrods cleaned and in
Milled rocker towers
Both turbos are going to drain into the pan via a -12AN hose for the secondary and -16AN hose for the primary so the stock drain gets plugged
Rockers in and bolted down
Side cover on and valve covers Installed.
