fields_mj
Okay. New pos cables. Great. Ground is suspect. Take a jumper cable and clip it to the block and the neg post. Or even better the starter. It's a quick diagnostic. Can do it to either battery or both or one at a time pretty quick. Disable the Gp controller so you aren't creaming the batteries with the gp's and melting the gp's down.
I suspect if the battery is not grounded well, it won't charge or provide the juice it should.
That was my thinking as well. Made it to NAPA just in time to get the cables. I didn't realize how SMALL 4ga is! Not only are they too small, but the eyelets on the ends are only 3/8", and won't accept the 1/2" mounting bolts that our engines use. Needless to say, they are going back. I may have a good set made at some point. I did remove all the connections on the Grounds, and clean them up as best I could, but it really didn't help much. All the connections looked to be in really good shape other than being covered with dirt, oil, and grease. So I re-landed those and went and got another battery. Truck starts fine now. I'm going to continue to monitor my battery gauge during start up and see what it does. If it doesn't drop over the next few days, I'll likely go ahead and replace the 2nd battery. If it does, then I still have a problem. Maybe the Alternator?
One interesting note. While I had both batteries disconnected, I got a wild hair and ohmed out the positive and negative leads. To my surprise, it was only 2.4 ohms!!! Not Kohms, or Mohms, but just plain ohms. Started pulling wires off the bendix and checking those. Looks like I have a pair of wires that's tied to the same ring that come from up under the dash. Those were the only ones that didn't show an open circuit. I left that ring off when I hooked everything back up to try again (after cleaning ground connections, before new battery), and my guess is that these wires fed the fuse panel because without them everything in the cab was still dead. Hooked them back up, hit the key in cab and everything turned over, but still very slow (no surprise). Ohmed out the leads again and everything showed an open circuit (OL). Kinda wondering if my sloppy Ford steering column/starter key switch isn't shorting out a little bit and draining the batteries during the day.
Going to have to get a newer truck.... next year.... I hope.....
