rckslash2010
1988 F-350 Flatbed
I bought this truck last summer and I've been having problems with the blinkers ever since. Around Oct. I bought a new set of trailer lights and wired them in as far to the front of the truck as I could, trying to weed out all the bad wiring that's been coupled up throughout the years. Using a tester I found all the wires needed, but the left turn signal. It's a light green wire with an orange strip through it. I got tired of messing with it so I ran a wire from the front blinker and hooked it up to the rear one, this worked for the blinker, but no brake lights. I've been running it like that all winter, and know that I have a little time on my hands, I'm gonna fix it. B.t.w. the front right blinker and running light went out somewhere along the way,(and it's not the bulb).
I figured it was the blinker switch in the steering column, probably still is the problem. Yesterday I tore into it. The little butterfly wire's were corroded, and so were the contacts. I cleaned them up and flipped the switch to the left and I had flashing power on the green/ brown strip wire. So I put everything back together and had power to the green/ brown strip wire under the truck, so I hooked it up to the tail lights and they worked.
That's when everything funny started happening. I pushed on the brake to see if the tail light would light, and all the running lights came on and the door buzzer when off. Now I have no left turn signal in the rear again. Today I started messing around with the front blinker, and got the running lights to work on it, but no blinker. If I turn the flashers on, I'll get all 4 blinker lights to work,as long as I don't put my foot on the brake. When I do that all the running lights come on and the flasher stops. The door buzzer goes off when I press on the brakes, and if I keep my foot off the brake, it goes off every time the flasher flashes.
I didn't want to put out the money for a new switch, but it looks like that's what I'll have to do. Bumper 2 bumper quoted my $130 or something like that last summer. It sounds like that's not my only problem now, hopefully it is, but I don't see how that would have anything to do with my running lights coming on when I hit the brakes. For now I have right rear, and left front blinkers. And a whole lot of brake lights. What do y'all think? Start with the blinker switch and go from there? Sounds like I may have some grounding issues somewhere along the way. Thanks.
