Will start only sometimes? Water Temp light?
1992camarors
Van Wert, Ohio
Ok this morning before school I went out to go start my ole 6.9. And the engine temp light just lit up when I attempted to start it. But after turning the key a few times it decided it wanted to crank and fire up. The engine does not have any coolant or overheating problems with it, and it had been sitting over night and everything worked as it should including the glow plugs this morning. It was a good 50 degrees this morning too. So is this like a bad tmep. sensor or something, cause that engine was cold and not overheating like the senosr thinks it is? But the temp gauge works fine it when I drive it. So guys help me out on this one.
