I have a mysterious starting situation with my 91 in my sig. and I have done everything I can think of to solve it. The first thing I have done is install brand new motorcraft plugs( I ohm'ed them before I installed them too). Then I replaced the glow plug relay and cleaned out the connector that supplys power to the relay and made sure both fuseable links were good. Then I did the manual glow plug conversion and replaced all the fuel return lines. Next came a new starter and tested the power cable to it for resistance. After doing all this it still will not start if it is below 30 degrees. If I plug it in it will fire right off. I know my glow plugs are working because my volt gauge goes way down when I activate them manually. I can glow them for 15 seconds 2 times in a row and it wont even attempt to fire. Plug it in for 2 hrs and bam fires on the first crank! The injectors have been replaced recently and I just timed the engine to about 8 degrees and my advance mech. seems to be working. The cold advance and fast idle is working too. I did a compression check and I have over 400 psi on all cylinders after about 4 or 5 revolutions. I doubt I have a fuel drain-off issue because when I plug it in it fires right off without a hitch. What gives? I am starting to get very frustrated
