Well I did a little more investigating today, I took out number 2 glow plug and grounded it to metal and hooked it up. It got super hot, so the plugs are definately working. Then I put a hair dryer on the injection pump to see if there was some anamoly with the pump being cold= no cold start. That did nothing. Then I got pissed and spayed some carb cleaner in the air cleaner, Bam she fired right up! So I am at the conclusion that either my starter isnt spinning the motor fast enough or I am not building enough compression to fire it off. I know when I did the comperssion test it took about 4 or 5 revolutions to build to about 400-425 psi(all cylinders were even) but that was when the motor was fairly warm. Does that sound about right? The starter is a reman from auto zone. It does seem to spin the motor fairly slow when its cold, but i imagine it would being that it is around 0 degrees here in wisconsin in the morning. My batteries are are fairly new from napa and they are 850 cca. If I plug it in it will fire up instantly. I tested all the battery cables for voltage drop(including the negatives) and the most I have is like .2 volts. If its cold NO GO!! It starting to **** me off. My dads cummins will fire off without even waiting for the grid heaters to cycle! This thing will not even attempt to start.
