will a 460 zf bolt to a 7.3??
Dieselcrawler
Professional wrench holder
Staff member
Quakertown Pa
The top two bolts line up. Take the adapter off the back of a pickup engine, bolt it to the front of the zf. Now use that as a guide to drill the holes
junk
Paullina, IA
This is a pic showing the adapter from a Pickup/van 7.3 laid on top of the ZF-5. The top two bolt holes need to be drilled to 1/2". They match up with the adapter and can be bolted during drilling. Then use the remaining holes as a drill guide. It's really simple. I used a mag drill, but a hand drill would work fine. My build thread in my signature has more details. It's towards the end.
Copy from my build.
Drilled the 5-speed I bought so it will bolt to a Diesel.
Used a magnetic based drill that attached to the metal adapter plate to do most of the holes. Lots of ways to do this, but when you work for a machine shop you have access to some pretty nice tools.
1. Drilled out the two top holes in transmission with a hand drill using a 1/2" bit.
2. Bolted adapter plate to the transmission through the two top holes that were enlarged. I made a couple 1/2-13 nuts with a chamfer on them similar to a lug nut to center the bolts in the holes on the adapter plate.
3. I drilled dowel pin holes using a V code drill bit. It's a .377" drill bit. So just slightly larger than a 3/8" dowel.
4. I put a couple 3/8" bolts through the dowel holes to help hold the plate down while I drill the remaining holes.
5. I used the mag drill with a 17/32 bit (.531") to drill the remaining 4 holes in the transmission. I did have to remove the 3/8" bolts at times to give room for the mag drill base.
Jeremy
jwalterus
Made in America
Garrison, ND
you should do a new thread with just that post so it can be added to the tech section and we can avoid this in the future ;Sweet
hesutton
The Anti-Anderson
Bowling Green, KY
Heath
Yes a 4 flute end mill is THE tool for the holes BTW just as Heath has shown...if you can start as @junk has shown...use a mage base drill with a 4 flute mill as @hesutton has shown you should hqve zero issues adapting it to fit.
Good luck
Laine D
Northern California
I’m not trying to hijack this thread even though it’s an oldie. Are the wide ratio gears bad on a diesel?
Randy Bush
Great Falls, Mt
No they are not , It is what I have in my 93 IDIT dually. Both wide and close where used in diesels, believe though the close was more common.
u2slow
bilge rat
PNW
Depends how you use the truck.
Ultimately you can get a heavier load rolling with the wide, but has the penalty of big rpm gaps between shifts.
The close lets you stay in the powerband better, with smaller rpm gaps. Tends to be nicer to drive. More like gears 2-6 in a newer 6 speed diesel truck.
The puzzler is why Ford decided on unique close-ratios for a diesel that revved to 4k, when Dodge stuck with wide ratios with the cummins revving to only 3k rpm. o_O
Laine D
Northern California
@u2slow i don’t really pull that much other than the occasional jet boat.. I got this transmission for free though. Would I be able to swap 2nd and 3rd out for the close ratio gears?
carsonlhammond
Jackson, CA
I think its cause the cummins can pull the low end lugs, the idi cannot.
u2slow
bilge rat
PNW
I haven't tried it. The reading I did years ago led me to believe you swapped all the guts, or changed the front half of the case. You may have to stay all S42 or all S47 (i.e. not mix and match) not 100% sure though.
I think this is one of guys who actually did it.
https://expeditionportal.com/forum/members/charlieaarons.760/
typ4
Newberg,OR
No I ran a 460 on my diesel zf for a couple years
Lance
