Hydro-idi
Black smoke = high egt's and wasted energy. If you can push more air into the engine, that will eliminate most of the black smoke while gaining more hp, efficiency, and overall engine longevity. Jason, I think the WW2 wheel will help reduce overall egt's and help clear up the black smoke. It is, however, somewhat normal for a turbo-ed engine to emit black smoke until turbo builds boost. If you have heavy black smoke under WOT while turbo is pushing max boost, this is a good indicator that you need to introduce more air into the engine to compensate for the heavy fuel output.
I think you will be fine with the turbo upgrade and junior moose IP. Mel builds an awesome line of moose pumps and stands behind them.
