who needs sleeves in a 7.3
This is why a 7/16 threaded hole can't be drilled and taped out to 1/2 inch.....
The 7/16 hole needs to be .3680 and the 1/2 inch hole needs to be.4219. that does not leave enough material for the 1/2 inch tap to cut a full thread from the block. All you can get is about half a thread thickness in the block. You end up with a thread thats only .0539 thick. Not near enough for a head bolt to hold on at peak torque. You would pull the threads out of the block.
flatlander
plays dirty when losing
ft. wayne IN
If it turns out that you are tinkering with a 6.9, I happen to have lots of good stuff for your untinkerin'. Studs and studs, ported polished heads, etc. . .Make you a deal but you have to take the whole motor.
Vincent
